Zum Hauptinhalt wechseln
Dell Precision 7710 Memory Module Replacement
Was du brauchst
  1. Dell Precision 7710 Memory Module Replacement, Battery Cover: Schritt 1, Bild 1 von 1
    • Slide the release latch to unlock the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
  2. Dell Precision 7710 Memory Module Replacement, Battery: Schritt 2, Bild 1 von 1
    • Slide the release latch to unlock the battery [1].
    • Lift and remove the battery from the computer [2].
  3. Dell Precision 7710 Memory Module Replacement, Base Cover: Schritt 3, Bild 1 von 1
    • Remove the screws that secure the base cover to the computer [1].
    • Slide and lift the base cover away from the computer [2].
  4. Dell Precision 7710 Memory Module Replacement, KeyBoard: Schritt 4, Bild 1 von 2 Dell Precision 7710 Memory Module Replacement, KeyBoard: Schritt 4, Bild 2 von 2
    • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
    • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
  5. Dell Precision 7710 Memory Module Replacement: Schritt 5, Bild 1 von 1
    • Remove the screws that secure the keyboard to the computer [1].
    • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
  6. Dell Precision 7710 Memory Module Replacement, Memory Module: Schritt 6, Bild 1 von 1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
  7. Dell Precision 7710 Memory Module Replacement: Schritt 7, Bild 1 von 1
    • Remove the screw that secures the memory shield to the computer [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,678
