Was du brauchst
Slide the battery release latches to the unlock position.
Slide and remove the battery from the computer
Loosen the captive screw that secures the access panel to the base of the computer.
Slide the access panel towards the front of the computer.
Lift the access panel up and away from the computer.
Carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the connector.
