Was du brauchst
Slide the battery release latch into the unlock position.
Remove the battery from the system.
Remove the screws that secure the base cover to the computer.
Press the rubber feet towards the rear of the system to disengage the bottom door.
Remove the base cover from the computer.
Remove the screws securing the hard drive bracket in place.
Remove the screw securing the hard drive latch in place
Slide the hard drive release latch into the unlock position.
Remove the hard drive bracket from the system.
Flex the hard drive bracket outward and press the hard drive upwards from the bottom.
Remove the hard drive from the hard drive bracket.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
