Was du brauchst
Slide the battery release latch into the unlock position.
Remove the battery from the system.
Using a plastic scribe, pry under the keyboard trim to release it from the computer.
Work your way around the sides and bottom edge of the keyboard trim.
Lift up to remove the keyboard trim from the unit.
Remove the screws securing the keyboard in place.
Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
Disconnect the keyboard data cable from the system board.
Remove the keyboard.
Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
Disconnect the keyboard data cable from the back of the keyboard.
Eine weitere Person hat diese Anleitung absolviert.
