Zum Hauptinhalt wechseln
Dell Precision M4600 Memory Module Replacement
Was du brauchst
  1. Dell Precision M4600 Memory Module Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Precision M4600 Memory Module Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery release latch into the unlock position.
    • Remove the battery from the system.
  2. Dell Precision M4600 Memory Module Replacement, Base Cover: Schritt 2, Bild 1 von 3 Dell Precision M4600 Memory Module Replacement, Base Cover: Schritt 2, Bild 2 von 3 Dell Precision M4600 Memory Module Replacement, Base Cover: Schritt 2, Bild 3 von 3
    • Remove the screws that secure the base cover to the computer.
    • Press the rubber feet towards the rear of the system to disengage the bottom door.
    • Remove the base cover from the computer.
  3. Dell Precision M4600 Memory Module Replacement, Keyboard Trim: Schritt 3, Bild 1 von 3 Dell Precision M4600 Memory Module Replacement, Keyboard Trim: Schritt 3, Bild 2 von 3 Dell Precision M4600 Memory Module Replacement, Keyboard Trim: Schritt 3, Bild 3 von 3
    • Using a plastic scribe, pry under the keyboard trim to release it from the computer.
    • Work your way around the sides and bottom edge of the keyboard trim.
    • Lift up to remove the keyboard trim from the unit.
  4. Dell Precision M4600 Memory Module Replacement, KeyBoard: Schritt 4, Bild 1 von 3 Dell Precision M4600 Memory Module Replacement, KeyBoard: Schritt 4, Bild 2 von 3 Dell Precision M4600 Memory Module Replacement, KeyBoard: Schritt 4, Bild 3 von 3
    • Remove the screws securing the keyboard in place.
    • Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
    • Disconnect the keyboard data cable from the system board.
  5. Dell Precision M4600 Memory Module Replacement: Schritt 5, Bild 1 von 3 Dell Precision M4600 Memory Module Replacement: Schritt 5, Bild 2 von 3 Dell Precision M4600 Memory Module Replacement: Schritt 5, Bild 3 von 3
    • Remove the keyboard.
    • Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
    • Disconnect the keyboard data cable from the back of the keyboard.
  6. Dell Precision M4600 Memory Module Replacement: Schritt 6, Bild 1 von 1
    • Peel the keyboard data cable away from the keyboard and remove.
  7. Dell Precision M4600 Memory Module Replacement, Memory Module: Schritt 7, Bild 1 von 2 Dell Precision M4600 Memory Module Replacement, Memory Module: Schritt 7, Bild 2 von 2
    • Flip the the Bottom
    • Gently pry the retention clips away from the memory modules.
    • Remove the memory modules from the computer.
  8. Dell Precision M4600 Memory Module Replacement: Schritt 8, Bild 1 von 2 Dell Precision M4600 Memory Module Replacement: Schritt 8, Bild 2 von 2
    • Flip to the Top.
    • Gently pry the retention clips away from the memory module.
    • Remove the memory module from the computer.
Abschluss
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,212
