Zum Hauptinhalt wechseln
Dell Precision M4800 Wi-Fi Card Replacement
Was du brauchst
  1. Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 1 von 3 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 2 von 3 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 3 von 3
    • Ensure that all electrical sources are removed and turned off.
    • Unplug the charger from the laptop and shut it down.
    • Flip the computer, so the bottom is facing upwards.
    • Slide the release latch to release the battery.
    • Lift and remove the battery from the laptop.
  2. Dell Precision M4800 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
    • Slide the base cover towards the rear of the laptop.
    • Lift the base cover and remove it from the laptop.
  3. Dell Precision M4800 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 3 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 3 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the black and white antenna cables by carefully pulling them upwards away from the card, being cautious to not bend the connector.
    • For the antenna pins a simple and slight nudge is usually enough, but remember that these pins are somewhat delicate.
    • Remove the screw.
  4. Dell Precision M4800 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the Wi-Fi card.
  5. Dell Precision M4800 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Slide the replacement Wi-Fi card into the slot.
    • Tighten the screw securing the Wi-Fi card.
  6. Dell Precision M4800 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 2 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 6, Bild 2 von 2
    • Connect both antenna cables back to the same places according to the color code on the Wi-Fi card.
  7. Dell Precision M4800 Wi-Fi Card Replacement: Schritt 7, Bild 1 von 3 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 7, Bild 2 von 3 Dell Precision M4800 Wi-Fi Card Replacement: Schritt 7, Bild 3 von 3
    • Slide the base cover towards the front of the laptop.
    • Slide the battery back into its place.
    • Make sure to put a little pressure on it if the battery is not fully in place. The battery release latch will automatically click back to the locked position.
Abschluss
Naveen
195 Reputation
1 Anleitung geschrieben
York University, Team B-19, Woodhouse Fall 2023 Mitglied von York University, Team B-19, Woodhouse Fall 2023
YORK-WOODHOUSE-F23SBG19
2 Mitglieder
1 Kommentar zur Anleitung
Great guide, well-written and concise. Thank you for sharing your knowledge and expertise. Best regards
Loren Martin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 47
Insgesamt: 842
