Zum Hauptinhalt wechseln
Dell Precision M6400 Hard Drive Replacement
Was du brauchst
  1. Dell Precision M6400 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 Hard Drive Replacement, Base Cover: Schritt 2, Bild 1 von 1
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Loosen the two captive screws on the HDD1 carrier, and remove the carrier.
    • Push in, then pull up on the safety loop to remove the cover.
    • Use the pull tab to disconnect the HDD1 from the connector on the system board, and remove the HDD1 from the computer.
  4. Dell Precision M6400 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the two M3 x 3-mm screws that secure the pull tab to the HDD1.
    • Set the pull tab aside to use with the replacement HDD1.
  5. Dell Precision M6400 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the two M3 x 3-mm screws that secure the carrier to the computer.
    • Pull up on the pull tab to remove the carrier.
  6. Dell Precision M6400 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the two M3 x 3-mm screws that secure the carrier to the HDD2.
    • Remove the carrier from the HDD2. If your computer does not have an HDD2, remove the hard drive place-holder from the carrier.
    • Remove the interposer from the HDD2 or the place-holder, and set the interposer aside.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 32
Insgesamt: 4,116
