Zum Hauptinhalt wechseln
Dell Precision M6400 KeyBoard Replacement
Was du brauchst
  1. Dell Precision M6400 KeyBoard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 KeyBoard Replacement, Base Cover: Schritt 2, Bild 1 von 1
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 KeyBoard Replacement, LED Cover: Schritt 3, Bild 1 von 1
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
  4. Dell Precision M6400 KeyBoard Replacement, KeyBoard: Schritt 4, Bild 1 von 1
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 942
