Was du brauchst
Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
There are two 1.5mm screws that will be taken off using a Phillips #00 screw driver.
The RAM is held in place by two prongs. By pulling the two prongs lightly away from the chip the RAM is able to be pulled out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
