Was du brauchst
Slide the release latch to unlock the battery.
Flip and remove the battery from the computer.
Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
Flip and remove the base cover from the computer
Remove the screws that secure the primary hard drive to the computer. Slide the primary hard -drive latch to the unlock position and pull out the hard drive from the computer.
Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
Remove the screw that secure that secondary hard drive in place.
Pull the tab upward and remove the secondary hard drive from the computer.
Remove the screw that secure secondary hard drive to the bracket.
Remove the secondary hard drive from the bracket.
4 weitere Personen haben diese Anleitung absolviert.
