Einleitung
Use this guide to replace the battery in the Dell Streak 7. This guide will show the steps required to replace the battery in the tablet.
Was du brauchst
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
With the Torx screwdriver, remove the two 4mm screws.
Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
Using the spudger, disconnect the ribbon cable by lifting up on the connector.
With the spudger, disconnect the antenna cable located on the module.
Using tweezers, remove the tape connected to the GSM module.
Using the spudger, disconnect the front camera by lifting up on the connector.
Use the spudger to lift up and detach the cable connecting the battery to the motherboard.
3 weitere Personen haben diese Anleitung absolviert.
