Einleitung
Use this guide to replace the headphone jack on your Dell Streak 7. This guide will show you how to remove the old headphone jack.
Was du brauchst
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
With the Torx screwdriver, remove the two 4mm screws.
Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
Using the spudger, disconnect the ribbon cable by lifting up on the connector.
Eine weitere Person hat diese Anleitung absolviert.
