Zum Hauptinhalt wechseln
Dell Streak 7 Screen Replacement
Was du brauchst
  1. Dell Streak 7 Screen  Replacement, Front Panel Assembly: Schritt 1, Bild 1 von 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Screen  Replacement: Schritt 2, Bild 1 von 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Screen  Replacement: Schritt 3, Bild 1 von 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Screen  Replacement: Schritt 4, Bild 1 von 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Screen  Replacement: Schritt 5, Bild 1 von 2 Dell Streak 7 Screen  Replacement: Schritt 5, Bild 2 von 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Screen  Replacement: Schritt 6, Bild 1 von 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Screen  Replacement: Schritt 7, Bild 1 von 2 Dell Streak 7 Screen  Replacement: Schritt 7, Bild 2 von 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Screen  Replacement, Screen: Schritt 8, Bild 1 von 1
    • Using the screwdriver, remove the 3mm Torx T5 screws around the metal housing.
  9. Dell Streak 7 Screen  Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, peel off the tape securing the screen to the metal cage around it.
  10. Dell Streak 7 Screen  Replacement: Schritt 10, Bild 1 von 2 Dell Streak 7 Screen  Replacement: Schritt 10, Bild 2 von 2
    • Pull out the ribbon cables through the opening in the metal cage.
    • Lift up the metal cage surrounding the screen by swinging the cage from one side.
  11. Dell Streak 7 Screen  Replacement: Schritt 11, Bild 1 von 1
    • Remove the screen by lifting the screen from the front glass.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 4-6, Passmore Fall 2016 Mitglied von USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 480
