Zum Hauptinhalt wechseln
Dell Studio 1435 Hard Drive Replacement
Was du brauchst
  1. Dell Studio 1435 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch to the side.
    • Slide the battery out of the battery bay.
  2. Dell Studio 1435 Hard Drive Replacement, Base Cover: Schritt 2, Bild 1 von 1
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
  3. Dell Studio 1435 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Remove the two screws on the hard drive assembly.
  4. Dell Studio 1435 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Pull the pull tab to disconnect the hard drive assembly from the system board connector.
    • Pull the interposer to detach it from the hard drive.
    • Remove the four screws (two on either side) to detach the hard drive cage from the hard drive.
    • Lift the hard drive cage off the hard drive.
Abschluss
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 350
