Was du brauchst
Slide the battery release latch to the side.
Slide the battery out of the battery bay.
Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
Pull the pull tab to disconnect the hard drive assembly from the system board connector.
Pull the interposer to detach it from the hard drive.
Remove the four screws (two on either side) to detach the hard drive cage from the hard drive.
Lift the hard drive cage off the hard drive.
