Was du brauchst
Slide the battery release latch until it clicks into place.
Slide the battery out of the battery bay.
Turn the computer over and loosen the captive screw on the memory module cover.
Remove the memory module cover.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the memory module connector.
