Ersatzteile
Kein Ersatzteil erforderlich.
  1. Slide the battery release latch until it clicks into place.
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • CAUTION: Do not touch the processor thermal-cooling assembly. Processor components should be removed only by trained support personnel.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the four screws securing the hard drive assembly to the computer.
    • Remove the four screws securing the hard drive assembly to the computer.
    • Pull the hard drive cable pull-tab to disconnect the cable from the system board connector.
    • Pull on the hard drive pull-tab to lift the hard drive assembly from the bay.
  5. Remove the four M3 x 3-mm screws securing the hard drive cage to the hard drive.
    • Remove the four M3 x 3-mm screws securing the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
  6. Disconnect the hard drive cable from the connector on the hard drive..
    • Disconnect the hard drive cable from the connector on the hard drive..
    • NOTICE: When the hard drive is not in the computer, store it in protective antistatic packaging. For more information, see "Protecting Against Electrostatic Discharge" in the safety information that shipped with your computer.
Abschluss
Johnathan Hammond
35.735 Reputation
408 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 8
