Zum Hauptinhalt wechseln
Dell Studio 1536 Memory Module Replacement
Was du brauchst
  1. Dell Studio 1536 Memory Module Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Dell Studio 1536 Memory Module Replacement, Base Cover: Schritt 2, Bild 1 von 1
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • CAUTION: Do not touch the processor thermal-cooling assembly. Processor components should be removed only by trained support personnel.
  3. Dell Studio 1536 Memory Module Replacement, Memory Module: Schritt 3, Bild 1 von 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Abschluss
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 36
