Was du brauchst
Place the laptop lid down so the underside is visible.
Pull battery release switch and gently pull the battery directly away from the switch.
Unscrew all of the 6.0 mm screws with a Phillips #1 screwdriver holding the hard drive cage on the computer.
Pull tab to unplug the drive from the computer
Pull the hard drive out of the hard drive tray.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Straightforward process with step by step guide. Thank you Zach.
