Einleitung
To be able to access certain components like the hard drive or motherboard of the Dell Studio 1555, the back panel will need to be removed. A Phillips 1 screwdriver is required for this guide.
Was du brauchst
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Loosen the three 5mm screws from the back panel using the # 1 Philips screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
