Einleitung
If your screen becomes unresponsive you may need to replace it. A Philips 1 screwdriver and a plastic opening tool are required for this guide.
Was du brauchst
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Insert a plastic opening tool between the bezel and the display cover.
Wiggle it to the release the latches.
Separate the bezel from the cover.
Remove the four 3 mm screws securing the LCD using the #1 Phillips screwdriver.
Separate the LCD assembly from the display cover so you will be able to access the webcam cable.
Unplug the camera cable.
Place the LCD face down on the top cover.
Remove the sticky tape securing the video cable connector.
Unplug the video cable from the screen.
Remove the LCD from the laptop.
Remove the four 3mm screws holding the mounting brackets using the #1 Phillips screwdriver. Two on each side.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
