Einleitung
You may need to replace your keyboard due to failure. You will need a Phillips 1 screwdriver for this guide.
Was du brauchst
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
Flip the laptop over and flatten it out as much as possible.
Unsnap the media control cover from the laptop starting nearest to the display.
Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
