Einleitung
This guide will show you how to remove or replace the hard drive (HDD) in a Dell Studio 1737.
Was du brauchst
Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
Unscrew the 8 Phillips head screws marked in the photo.
Use a plastic opening tool to pry the panel away from the laptop body.
Lift the panel up and away.
Detach Hard drive from SATA connector.
Pull hard drive up and out pulling connector out of the way.
3 weitere Personen haben diese Anleitung absolviert.
