Einleitung
This guide will demonstrate how to remove or replace the keyboard of a Dell Studio 1737 laptop.
Was du brauchst
Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
Pry black panel away from laptop body starting at the base of the screen
Flip the panel over onto the keyboard
Detach the ribbon cable from the motherboard as shown
Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
Lift from the top of the keyboard and flip it over onto the palmrest
2 weitere Personen haben diese Anleitung absolviert.
