Einleitung
RAM can be responsible for bluescreens and other difficult-to-diagnose errors; this guide will instruct you how to replace, remove, or add RAM to your Laptop
Was du brauchst
Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
Unscrew the 8 Phillips head screws marked in the photo.
Use a plastic opening tool to pry the panel away from the laptop body.
Lift the panel up and away.
Release RAM sticks by pulling clips out in opposite directions of each other.
Pull RAM stick up and out.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
