Zum Hauptinhalt wechseln
Dell Studio 1747 Hard Drive Replacement
Was du brauchst
  1. Dell Studio 1747 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Dell Studio 1747 Hard Drive Replacement, Base Cover: Schritt 2, Bild 1 von 1
    • Remove the six screws that secure the base cover to the computer base.
    • Lift the base cover off the computer at an angle as shown in the following illustration.
  3. Dell Studio 1747 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 3 Dell Studio 1747 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 3 Dell Studio 1747 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 3 von 3
    • Remove the four screws that secure the hard drive assembly to the computer base.
    • Using the pull-tab, slide the hard drive towards the left to disconnect the hard drive assembly from the connector on the system board.
    • Lift the hard drive assembly out of the computer base.
    • Remove the four screws that secure the hard drive cage to the hard drive.
    • Lift the hard drive off the hard drive cage.
    • Pull the interposer to disconnect it from the hard drive.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 953
