Zum Hauptinhalt wechseln
Dell Studio XPS 1647 Hard Drive Replacement
Was du brauchst
  1. Dell Studio XPS 1647 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch to the side. {2}
    • Slide the battery out of the battery bay. {1}
  2. Dell Studio XPS 1647 Hard Drive Replacement, Base Cover: Schritt 2, Bild 1 von 1
    • Loosen the ten captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
  3. Dell Studio XPS 1647 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Remove the three screws securing the hard drive assembly to the computer base.
    • Pull the blue pull-tab to disconnect the hard drive assembly from the system board connector.
    • Lift the hard drive assembly out of the computer base.
  4. Dell Studio XPS 1647 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • NOTICE: When the hard drive is not in the computer, store it in protective antistatic packaging .
    • Remove the four screws that secure the hard drive bracket to the hard drive and remove the bracket.
  5. Dell Studio XPS 1647 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Pull the interposer to disconnect it from the hard drive.
Abschluss
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 285
