Zum Hauptinhalt wechseln
Dell VRP100 Auxiliary Cord Replacement
Was du brauchst
  1. Dell VRP100 Auxiliary Cord Replacement, Cover Panel: Schritt 1, Bild 1 von 3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: Schritt 1, Bild 2 von 3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: Schritt 1, Bild 3 von 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Auxiliary Cord Replacement: Schritt 2, Bild 1 von 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Auxiliary Cord Replacement: Schritt 3, Bild 1 von 3 Dell VRP100 Auxiliary Cord Replacement: Schritt 3, Bild 2 von 3 Dell VRP100 Auxiliary Cord Replacement: Schritt 3, Bild 3 von 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Auxiliary Cord Replacement: Schritt 4, Bild 1 von 3 Dell VRP100 Auxiliary Cord Replacement: Schritt 4, Bild 2 von 3 Dell VRP100 Auxiliary Cord Replacement: Schritt 4, Bild 3 von 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: Schritt 5, Bild 1 von 3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: Schritt 5, Bild 2 von 3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: Schritt 5, Bild 3 von 3
    • Separate the external connector of the auxiliary cord.
    • A spudger may be needed to separate the connector.
  6. Dell VRP100 Auxiliary Cord Replacement: Schritt 6, Bild 1 von 2 Dell VRP100 Auxiliary Cord Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  7. Dell VRP100 Auxiliary Cord Replacement: Schritt 7, Bild 1 von 3 Dell VRP100 Auxiliary Cord Replacement: Schritt 7, Bild 2 von 3 Dell VRP100 Auxiliary Cord Replacement: Schritt 7, Bild 3 von 3
    • In the top right corner of the motherboard panel, peel back the yellow tape covering the bundled auxiliary cable connector using tweezers.
    • Carefully pull out the bundled cable connectors.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Chris Grabow
285 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G1, White Fall 2018 Mitglied von Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Hello, where i can buy the aux cable?
Domenico Rescigno - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 4
Letzten 30 Tage: 12
Insgesamt: 583
