Zum Hauptinhalt wechseln
Dell VRP100 Camera Replacement
Was du brauchst
  1. Dell VRP100 Camera Replacement, Cover Panel: Schritt 1, Bild 1 von 3 Dell VRP100 Camera Replacement, Cover Panel: Schritt 1, Bild 2 von 3 Dell VRP100 Camera Replacement, Cover Panel: Schritt 1, Bild 3 von 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Camera Replacement: Schritt 3, Bild 1 von 3 Dell VRP100 Camera Replacement: Schritt 3, Bild 2 von 3 Dell VRP100 Camera Replacement: Schritt 3, Bild 3 von 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Camera Replacement: Schritt 4, Bild 1 von 3 Dell VRP100 Camera Replacement: Schritt 4, Bild 2 von 3 Dell VRP100 Camera Replacement: Schritt 4, Bild 3 von 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Camera Replacement, Camera: Schritt 5, Bild 1 von 3 Dell VRP100 Camera Replacement, Camera: Schritt 5, Bild 2 von 3 Dell VRP100 Camera Replacement, Camera: Schritt 5, Bild 3 von 3
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  6. Dell VRP100 Camera Replacement: Schritt 6, Bild 1 von 2 Dell VRP100 Camera Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 2.5mm PH000 screws from the motherboard by rotating counter-clockwise.
    • Remove the four 3.9mm PH000 screws from the white casing by rotating counter-clockwise.
  7. Dell VRP100 Camera Replacement: Schritt 7, Bild 1 von 2 Dell VRP100 Camera Replacement: Schritt 7, Bild 2 von 2
    • Remove the flat-topped connector by lifting it straight up from the motherboard.
    • Carefully remove the camera from the casing with the blunt nose tweezers by holding onto the copper tape.
    • To reinstall, line up the connectors and firmly push until you hear a pop.
Abschluss
Lauren Monzon
217 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G1, White Fall 2018 Mitglied von Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 15
Insgesamt: 306
