Zum Hauptinhalt wechseln
Dell VRP100 Lens Replacement
Was du brauchst
  1. Dell VRP100 Lens Replacement, Cover Panel: Schritt 1, Bild 1 von 3 Dell VRP100 Lens Replacement, Cover Panel: Schritt 1, Bild 2 von 3 Dell VRP100 Lens Replacement, Cover Panel: Schritt 1, Bild 3 von 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Lens Replacement: Schritt 2, Bild 1 von 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Lens Replacement: Schritt 3, Bild 1 von 3 Dell VRP100 Lens Replacement: Schritt 3, Bild 2 von 3 Dell VRP100 Lens Replacement: Schritt 3, Bild 3 von 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Lens Replacement: Schritt 4, Bild 1 von 3 Dell VRP100 Lens Replacement: Schritt 4, Bild 2 von 3 Dell VRP100 Lens Replacement: Schritt 4, Bild 3 von 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Lens Replacement, Lens: Schritt 5, Bild 1 von 2 Dell VRP100 Lens Replacement, Lens: Schritt 5, Bild 2 von 2
    • Deattach the black cover from the lens with a metal spudger.
    • This will “click” back into place during replacement.
  6. Dell VRP100 Lens Replacement: Schritt 6, Bild 1 von 3 Dell VRP100 Lens Replacement: Schritt 6, Bild 2 von 3 Dell VRP100 Lens Replacement: Schritt 6, Bild 3 von 3
    • Gently insert the metal spudger between the lens and the lens casing.
    • Rotate the spudger around the exterior of the lens and lens housing, separating them.
    • The lens is held in place with an adhesive that will have to be applied during reassembly.
  7. Dell VRP100 Lens Replacement: Schritt 7, Bild 1 von 1
    • Holding the lens around the outside, gently lift it out of its housing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Chris Grabow
285 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G1, White Fall 2018 Mitglied von Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 776
