Zum Hauptinhalt wechseln
Dell VRP100 Screen Replacement
Was du brauchst
  1. Dell VRP100 Screen Replacement, Cover Panel: Schritt 1, Bild 1 von 3 Dell VRP100 Screen Replacement, Cover Panel: Schritt 1, Bild 2 von 3 Dell VRP100 Screen Replacement, Cover Panel: Schritt 1, Bild 3 von 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Screen Replacement: Schritt 3, Bild 1 von 3 Dell VRP100 Screen Replacement: Schritt 3, Bild 2 von 3 Dell VRP100 Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Screen Replacement: Schritt 4, Bild 1 von 3 Dell VRP100 Screen Replacement: Schritt 4, Bild 2 von 3 Dell VRP100 Screen Replacement: Schritt 4, Bild 3 von 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Screen Replacement, Screen: Schritt 5, Bild 1 von 3 Dell VRP100 Screen Replacement, Screen: Schritt 5, Bild 2 von 3 Dell VRP100 Screen Replacement, Screen: Schritt 5, Bild 3 von 3
    • Remove the four 2.5 mm PH000 screws by rotating counter-clockwise.
    • Separate the lenses from the motherboard panel.
  6. Dell VRP100 Screen Replacement: Schritt 6, Bild 1 von 2 Dell VRP100 Screen Replacement: Schritt 6, Bild 2 von 2
    • Take off the tape using the blunt nosed tweezers to disconnect the flat-topped connector from the motherboard.
    • The screen is attached to the motherboard using an adhesive.
  7. Dell VRP100 Screen Replacement: Schritt 7, Bild 1 von 3 Dell VRP100 Screen Replacement: Schritt 7, Bild 2 von 3 Dell VRP100 Screen Replacement: Schritt 7, Bild 3 von 3
    • Lift the yellow tape with tweezers.
    • Remove the ribbon cable from the screen to the motherboard with tweezers.
  8. Dell VRP100 Screen Replacement: Schritt 8, Bild 1 von 3 Dell VRP100 Screen Replacement: Schritt 8, Bild 2 von 3 Dell VRP100 Screen Replacement: Schritt 8, Bild 3 von 3
    • Remove the six 3.4mm PH000 screws by rotating counter-clockwise connecting the back panel to the screen.
    • Remove the back panel from the screen by carefully pulling apart the two.
  9. Dell VRP100 Screen Replacement: Schritt 9, Bild 1 von 3 Dell VRP100 Screen Replacement: Schritt 9, Bild 2 von 3 Dell VRP100 Screen Replacement: Schritt 9, Bild 3 von 3
    • Peel away the screen with both hands.
    • A plastic opening tool may be required for removing the screen.
    • Adhesive may need to be reapplied during the rebuild.
Abschluss
Lauren Monzon
217 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G1, White Fall 2018 Mitglied von Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 771
