Zum Hauptinhalt wechseln
Dell Venue 7 Battery Replacement
Was du brauchst
  1. Dell Venue 7 Battery Replacement, Rear Case: Schritt 1, Bild 1 von 2 Dell Venue 7 Battery Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Venue 7 Battery Replacement, Battery: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
    Frag FixBot
  3. Dell Venue 7 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
    Frag FixBot
Abschluss
chaveza
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 11-4, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare zur Anleitung
I am purchase dell vaneu 7 8gb internal memory like_ion battery 15.17 wh EU 4100 price
Avind Kumar agrawal - Antwort Teilen
Dell vanue 7 tablat I want like_battery 15.17wh EU 4100 mah
Prices dell venue 7 li_I on battery 15.17 wh EU 4100mah
From were to purchase battery
shriyash Mhatre - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 46
Insgesamt: 7,918
