Zum Hauptinhalt wechseln
Dell Venue 7 Motherboard Replacement
Was du brauchst
  1. Dell Venue 7 Motherboard Replacement, Rear Case: Schritt 1, Bild 1 von 2 Dell Venue 7 Motherboard Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Venue 7 Motherboard Replacement, Battery: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
    Frag FixBot
  3. Dell Venue 7 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
    Frag FixBot
  4. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: Schritt 4, Bild 1 von 1
    • Use a spudger to disconnect the camera from the motherboard.
    Frag FixBot
  5. Dell Venue 7 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the camera from the device.
    Frag FixBot
  6. Dell Venue 7 Motherboard Replacement, Speaker: Schritt 6, Bild 1 von 2 Dell Venue 7 Motherboard Replacement, Speaker: Schritt 6, Bild 2 von 2
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
    Frag FixBot
  7. Dell Venue 7 Motherboard Replacement: Schritt 7, Bild 1 von 2 Dell Venue 7 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
    Frag FixBot
  8. Dell Venue 7 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the plastic covering on the speaker.
    Frag FixBot
  9. Dell Venue 7 Motherboard Replacement: Schritt 9, Bild 1 von 2 Dell Venue 7 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Gently pull on the wire and remove the speaker.
    Frag FixBot
  10. Dell Venue 7 Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 3 Dell Venue 7 Motherboard Replacement, Motherboard: Schritt 10, Bild 2 von 3 Dell Venue 7 Motherboard Replacement, Motherboard: Schritt 10, Bild 3 von 3
    • Disconnect the two remaining connections on the motherboard.
    • To remove the first connector, lift up the clasp and remove the ribbon cable.
    • To remove the second one, use a spudger to gently pry the connector from the motherboard.
    Frag FixBot
  11. Dell Venue 7 Motherboard Replacement: Schritt 11, Bild 1 von 2 Dell Venue 7 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
    Frag FixBot
  12. Dell Venue 7 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Lift and remove the motherboard from the device.
    Frag FixBot
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 11-4, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare zur Anleitung
unable to open the lock, can the mother board be changed
Amitabh Mishra - Antwort Teilen
Great article.
luisramonjimenez1986 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 45
Insgesamt: 4,883
