Einleitung
Many components are connected to the motherboard so confirm that all of the components work before you decide to replace the whole motherboard.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Remove the battery by pulling it from the edges and carefully peeling it off of the base.
Use a spudger to disconnect the camera from the motherboard.
Use a spudger to remove the ribbon cable that is around the speaker wire.
Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
8 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
unable to open the lock, can the mother board be changed
Great article.
