Einleitung
If you want to replace the speaker you must first get a new one. Once you do, then you are ready to follow these easy steps.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Remove the battery by pulling it from the edges and carefully peeling it off of the base.
Use a spudger to remove the ribbon cable that is around the speaker wire.
Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
2 weitere Personen haben diese Anleitung absolviert.
