Zum Hauptinhalt wechseln
Dell Venue 8 7840 Screen Replacement
Was du brauchst
  1. Dell Venue 8 7840 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Screen Replacement: Schritt 2, Bild 1 von 1
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Screen Replacement: Schritt 3, Bild 1 von 1
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Screen Replacement: Schritt 4, Bild 1 von 1
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Screen Replacement: Schritt 5, Bild 1 von 1
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Screen Replacement: Schritt 6, Bild 1 von 1
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Screen Replacement: Schritt 7, Bild 1 von 1
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Screen Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the connector from the tablet.
Abschluss
USF Tampa, Team 6-5, Remmell Fall 2016 Mitglied von USF Tampa, Team 6-5, Remmell Fall 2016
USFT-REMMELL-F16S6G5
3 Mitglieder
6 Anleitungen geschrieben
3 Kommentare
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
dengzc - Antwort
Where can I find a replacement screen for this device?
Karim Mohamed - Antwort
Is the OLED connected with EDP 30=pin FPC?
Ron King - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 1,394
