Einleitung
Your battery in your tablet may not be working. We will be replacing the battery of the Dell Venue 8.
Was du brauchst
Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
Remove the back panel of the device.
Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
4.45mm Silver screws
3.6mm Black screws
Gently snap the perimeter clips open, and remove the internal plastic case.
Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
Gently pry the battery away from the device with the plastic opening tool to remove it.
14 weitere Nutzer:innen haben diese Anleitung absolviert.
