Zum Hauptinhalt wechseln
Dell Venue 8 Speaker Replacement
Was du brauchst
  1. Dell Venue 8 Speaker Replacement, Rear Case/Midframe: Schritt 1, Bild 1 von 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Speaker Replacement: Schritt 2, Bild 1 von 3 Dell Venue 8 Speaker Replacement: Schritt 2, Bild 2 von 3 Dell Venue 8 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
  4. Dell Venue 8 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
Abschluss
Andrea
1.071 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 9-2, Leahy Winter 2015 Mitglied von USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 692
