Was du brauchst
Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
loosen the captive screws on the memory module cover, and then remove the memory module cover.
Use your fingertips to carefully spread apart the memory-module securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
