Was du brauchst
Slide the battery lock to the open position. {2}
Slide the battery latch release to the open position. (You may need to hold the latch release in the open position while removing the battery.){3}
Slide the battery out of the battery bay. {1}
Remove the M2.5 x 5-mm screw that secures the hard-drive compartment cover. {2}
Remove the cover and set it aside.{1}
Remove the two screws securing the hard drive to the hard-drive bracket.
Slide the hard drive out of the hard-drive bracket.
Pull the mylar tab to release the hard drive.
Lift the hard drive out of the computer.
