Zum Hauptinhalt wechseln
Dell Vostro 1310 Memory Module Replacement
Was du brauchst
  1. Dell Vostro 1310 Memory Module Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery lock to the open position. {2}
    • Slide the battery latch release to the open position. (You may need to hold the latch release in the open position while removing the battery.){3}
    • Slide the battery out of the battery bay. {1}
  2. Dell Vostro 1310 Memory Module Replacement, Memory Module: Schritt 2, Bild 1 von 1
    • Remove the M2.5 x 5-mm screw that secures the memory cover, and remove the cover and set it aside.
  3. Dell Vostro 1310 Memory Module Replacement: Schritt 3, Bild 1 von 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Abschluss
Johnathan Hammond
45.034 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 195
