Zum Hauptinhalt wechseln
Dell Vostro 1320 USB Port Replacement
Was du brauchst
  1. Dell Vostro 1320 USB Port Replacement, USB Port: Schritt 1, Bild 1 von 1
    • Remove the battery from the computer.
  2. Dell Vostro 1320 USB Port Replacement: Schritt 2, Bild 1 von 1
    • Remove all visible screws from the bottom of the computer.
  3. Dell Vostro 1320 USB Port Replacement: Schritt 3, Bild 1 von 3 Dell Vostro 1320 USB Port Replacement: Schritt 3, Bild 2 von 3 Dell Vostro 1320 USB Port Replacement: Schritt 3, Bild 3 von 3
    • Use a metal spudger to remover the covers of each section that you removed screws from.
    • Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
  4. Dell Vostro 1320 USB Port Replacement: Schritt 4, Bild 1 von 1
  5. Dell Vostro 1320 USB Port Replacement: Schritt 5, Bild 1 von 3 Dell Vostro 1320 USB Port Replacement: Schritt 5, Bild 2 von 3 Dell Vostro 1320 USB Port Replacement: Schritt 5, Bild 3 von 3
    • You must first unscrew the screws holding the wire in place.
    • Unhook the wire that the metal spudger is pointing at.
  6. Dell Vostro 1320 USB Port Replacement: Schritt 6, Bild 1 von 1
  7. Dell Vostro 1320 USB Port Replacement: Schritt 7, Bild 1 von 2 Dell Vostro 1320 USB Port Replacement: Schritt 7, Bild 2 von 2
    • Undo the screws holding the screen to the computer base.
  8. Dell Vostro 1320 USB Port Replacement: Schritt 8, Bild 1 von 1
    • Unplug the wires connecting the screen to the base.
    • The screen should come free and is able to be removed completely.
  9. Dell Vostro 1320 USB Port Replacement: Schritt 9, Bild 1 von 2 Dell Vostro 1320 USB Port Replacement: Schritt 9, Bild 2 von 2
    • Unplug the two blue labeled wires.
  10. Dell Vostro 1320 USB Port Replacement: Schritt 10, Bild 1 von 3 Dell Vostro 1320 USB Port Replacement: Schritt 10, Bild 2 von 3 Dell Vostro 1320 USB Port Replacement: Schritt 10, Bild 3 von 3
    • Detach the black plastic cover by loosening it with a metal spudger.
  11. Dell Vostro 1320 USB Port Replacement: Schritt 11, Bild 1 von 1
    • Unplug the wire that the metal spudger is pointing to.
  12. Dell Vostro 1320 USB Port Replacement: Schritt 12, Bild 1 von 1
    • Unscrew the USB port.
  13. Dell Vostro 1320 USB Port Replacement: Schritt 13, Bild 1 von 2 Dell Vostro 1320 USB Port Replacement: Schritt 13, Bild 2 von 2
    • Gently lift out the USB port.
Abschluss
Christie Lloyd
431 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 647
