Was du brauchst
Slide the release latch to unlock the battery [1].
Remove the battery from the computer [2].
Remove the screw that secures the optical drive to the computer [1].
Using a plastic scribe, push the tab to release the optical drive [2].
Slide the optical drive out of the computer [3].
Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
Disconnect the keyboard cable from the system board.
Lift the keyboard cable to remove it from the computer.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
