Was du brauchst
Using a scribe, pry the edges of the back cover from all sides [1].
Lift the back cover from the computer [2].
Disconnect the battery cable from the connector on the system board [1].
Remove the screws that secure the battery to the computer [2].
Lift and remove the battery from the computer [3].
Remove the screws that secure the SSD bracket [1] .
Lift to remove the SSD bracket from the computer [2].
Remove the screws that secure the SSD to the computer [1] .
Disconnect the SSD from its connector on the system board [2].
