Zum Hauptinhalt wechseln
Dell Vostro 14 5468 Solid-State Drive Replacement
Was du brauchst
  1. Dell Vostro 14 5468 Solid-State Drive Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Remove the screws that secure the back cover to the computer
  2. Dell Vostro 14 5468 Solid-State Drive Replacement: Schritt 2, Bild 1 von 1
    • Using a scribe, pry the edges of the back cover from all sides [1].
    • Lift the back cover from the computer [2].
  3. Dell Vostro 14 5468 Solid-State Drive Replacement, Battery: Schritt 3, Bild 1 von 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  4. Dell Vostro 14 5468 Solid-State Drive Replacement, Solid State Drive Bracket: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the SSD bracket [1] .
    • Lift to remove the SSD bracket from the computer [2].
  5. Dell Vostro 14 5468 Solid-State Drive Replacement, Solid-State Drive: Schritt 5, Bild 1 von 1
    • Remove the screws that secure the SSD to the computer [1] .
    • Disconnect the SSD from its connector on the system board [2].
Abschluss
Johnathan Hammond
45.034 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
Ein Kommentar
Step 4 Solid State Drive Bracket,My laptop doesn't have it.
Why not have it..?
How can I solve this problem.?
Model : dell vostro 5468
Sumit - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 473
