Einleitung
This guide will show you the proper steps to replace your screen on your Dell Vostro 1400
Was du brauchst
After flipping over the laptop, the battery is on the bottom side of the laptop.
Find the tabs on both the left and right side of the battery.
Remove the 6 screw hole covers surrounding the screen.
Remove the 6 screws that were underneath the screw covers.
Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
Remove the two (2.5mm x 5mm) screws at the top, by the camera.
Remove the two 5mm screws from the camera above the screen.
Remove the two 5mm screws from the bottom of the screen.
Lift up the black tag holding the camera and cable together.
Unplug the camera from the cable.
Remove the six 3mm screws on each side of the screen.
Remove the railing on each side of the screen.
2 weitere Personen haben diese Anleitung absolviert.
