Ersatzteile
Kein Ersatzteil erforderlich.
  1. Slide the release latch to release the battery [1].
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Remove the M2L3 screw that secures the optical drive to the computer [1].
    • Remove the M2L3 screw that secures the optical drive to the computer [1].
      • Using a plastic scribe, push the tab in the direction of the arrow indicated on the chassis. [2].
        • Slide the optical drive out of the computer [3].
    • Using a plastic scribe, release the five tabs from the slots located above the keyboard [1].
      • Flip the keyboard on the palm rest to access the keyboard connector cable under the keyboard [2].
    • Disconnect the keyboard cable from the system board.
      • Remove the keyboard from the computer.
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
      • Remove the M2L5 screws that secure the base cover [2].
    • Flip the computer and remove the screws (8 screws - M2.5L8; 3 screws - M2L2; 2 screws- M2L2) that secure the base cover to the computer.
    • Use a scribe to pry the edges of the base cover [1].
      • Lift the base cover and remove it from the computer [2].
    • Pull the clips securing the memory module until the memory module pops up [1].
      • Remove the memory module from the system board [2].
Abschluss
Johnathan Hammond
Mitglied seit 28.02.2018
35.878 Reputation
408 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 20
