Zum Hauptinhalt wechseln
Dell Vostro 15 3565 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 15 3565 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3565 Hard Drive Replacement, Optical-Disk Drive: Schritt 2, Bild 1 von 1
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3565 Hard Drive Replacement, KeyBoard: Schritt 3, Bild 1 von 1
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Dell Vostro 15 3565 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Dell Vostro 15 3565 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Dell Vostro 15 3565 Hard Drive Replacement, Base Cover: Schritt 6, Bild 1 von 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Dell Vostro 15 3565 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  8. Dell Vostro 15 3565 Hard Drive Replacement, Hard Drive: Schritt 8, Bild 1 von 1
    • Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Remove the screws that secure the hard drive assembly to the computer [3].
    • Lift the hard drive assembly away from the computer [4].
Abschluss
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 131
