Zum Hauptinhalt wechseln
Dell Vostro 15 3568 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 15 3568 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3568 Hard Drive Replacement, KeyBoard: Schritt 2, Bild 1 von 1
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  3. Dell Vostro 15 3568 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  4. Dell Vostro 15 3568 Hard Drive Replacement, Base Cover: Schritt 4, Bild 1 von 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  5. Dell Vostro 15 3568 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the screws that secure the base cover to the computer
  6. Dell Vostro 15 3568 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  7. Dell Vostro 15 3568 Hard Drive Replacement, Hard Drive: Schritt 7, Bild 1 von 1
    • Disconnect the hard drive cable from the connector on the system board [1].
    • Remove the screws that secure the hard drive assembly to the computer [2].
    • Lift the hard drive assembly away from the computer [3].
Abschluss
16 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 36
Letzte 30 Tage: 133
Insgesamt: 16,057
