Zum Hauptinhalt wechseln
Dell Vostro 15 5568 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 15 5568 Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the screws that secure the back cover to the computer.
  2. Dell Vostro 15 5568 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Using a scribe, pry the edges of the back cover from all sides [1].
    • Lift the back cover from the computer [2].
  3. Dell Vostro 15 5568 Hard Drive Replacement, Battery: Schritt 3, Bild 1 von 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  4. Dell Vostro 15 5568 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Lift the tab to disconnect the hard drive cable from the connector on the system board [1] .
    • Remove the screws that secure the hard drive to the computer [2].
    • Lift the hard drive from the computer [3].
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
2 Kommentare
Did work for me, many thanks. Only two small remarks.
a) Why remove the battery? I was installing a SSD in addition to the built in one (the hdd place was still empty). Attaching the hdd cable is possible without battery removal.
b) Disonnecting the battery showed to be a bit tricky. Pulling the cable is out of question, and pulling at the label part looked also not advisable. One-sided prying…not so good. Pushing the connector in the plane of the battery - need to be very careful, slipping may mean impulse force to the cable. I used careful two sided prying into the small spaces left and right of the connector.
Wolfgang - Antwort
Cuál es el tamaño de los tornillos de la cubierta posterior?
Elisa de Torres - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 3,612
